By mistake I ordered for my KH 250 a Zippy 2700maAh battery that 's 25C instead of 60C
G+_Bongo Nutty
You could use it, but I would keep an eye on it. I made a similar mistake with my 450. I ran it with a 25c 3s battery. It ran fine, up to the point that I started to fly aggressively. Then the battery started to overheat, then it start to balloon a little.
But that is also with a 450. A 250 is going to use a lot less power. And the ballooning may have been unrelated.
