G+_Michael Heinz Posted March 10, 2015 Share Posted March 10, 2015 So, what's the best way to mount your antenna? Let it dangle? strap it next to the battery? Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted March 10, 2015 Share Posted March 10, 2015 free air away from all you can, and match polarization between RF points. Link to comment Share on other sites More sharing options...
G+_Michael Heinz Posted March 10, 2015 Author Share Posted March 10, 2015 I'm afraid I didn't understand a word of that. Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted March 10, 2015 Share Posted March 10, 2015 What is the antenna doing? WiFi? Quad RC? FPV? What type of antenna? Dipole, colinear, yagi, cloverleaf, etc.? In general you want an antenna away from any conductive mass, (unless mass is used as the RF ground. But for quad battery would not be) You want both ends pointed the same way. If like your standard rubber-duck WiFi, both devices vertical or horizontal. If its a RC receiver, the manual should tell you how to run it. Your orig post was a bit vague. Kinda like asking how long is a piece of string. Link to comment Share on other sites More sharing options...
