Hi I 'm starting my first quad build I have decided to go with one that Padre suggested in ep...
G+_Stuart Davies
Hi.
I'm starting my first quad build. I have decided to go with one that Padre suggested in episode 122.
Here's a performance 230 Build:
Frame
RTF Mini Frame (230mm) $19.99
Motors
X2208-2300KV (Advanced) $61.00
Props
HQ 6x4.5 Carbon Composite $6.20
ESCs
F-20A Fire Red Series SimonK (RapidESC) ($8 x 4) $32.00
Flight Controller
Flip32+ $27.00.
Does anyone have any suggestions what battery would be best with this quad?
Nylon vs carbon props:  The DJI Phantom guys don't like the carbon for the most part.  Too stiff and introduce a lot of vibration into the videos (main reason fro a Phantom)  but some of the DJI customer have claimed "You don't need to balance props" so take it all with a grain of salt.
nylon dirt cheap, flexible don't hurt nearly as much.
carbon, rigid, cost more, will slice you good.
Practice/test flights on nylon, fun on carbon
Second on the fiberglass 6x45s. I fly both HQ fiber and carbon 6x45s on my mini, and the fiberglass props are 10x more resilient than the black carbon reinforced props. The carbon will explode every single time you hit something, fiber will take a few hits and keep on truckin. I bet the carbon give you slightly more lift, but you wont notice it as a beginner. That motor/prop combo will give you plenty of lift anyway. Probably too much honestly. i still have my throttle curve turned down. and ive been flying my setup for months.
