G+_Isaiah W Posted March 9, 2015 Share Posted March 9, 2015 Has anyone found an affordable Ethernet cable tester that measures transfer speed? Link to comment Share on other sites More sharing options...
G+_Taylor Graham Posted March 9, 2015 Share Posted March 9, 2015 Maybe someone else will chime in, but in my experience a laptop is the best option if you don't want to spend hundreds on one of those delicious fluke testers. Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted March 9, 2015 Share Posted March 9, 2015 Affordable? Not likely. I just got in the Fluke CIQ-100. But it was about $1100.US If the RasPi's had Gbit ports, I could see a sub $100 kludge solution. (but if 100Mbit is fine, I might play, have about 10 PI's here) One thing I'd like to point out, if you are looking for and need good results, don't skimp. As an analogy, When Apple first came out with Time Machine and Time Capsule, people were clambering to roll their own NAS to support it. But if its not 'qualified' do you want to use it for something critical like a back up? Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted March 10, 2015 Share Posted March 10, 2015 I haven't looked, to be honest. I've always just tried to follow best practices when cabling and that's typically enough for most situations. When I was doing that stuff regularly I only had a couple jobs that had to be "certified" and I usually had a 95% success rate. The remaining 5% would never be noticed in normal use. Link to comment Share on other sites More sharing options...
G+_Isaiah W Posted March 11, 2015 Author Share Posted March 11, 2015 Thanks for all the replies guys. I really like to verify my work when I'm done. I could always connect a computer to see if it can reach the internet. Link to comment Share on other sites More sharing options...
