Anyone ever create a network based garage door opener before?
G+_Ben Yanke
Anyone ever create a network based garage door opener before? I'm trying to decide the best way to do it....does the raz pi have network capabilities? I assume I'd need an external relay?
Nb: I have (or can have) access to live cat5 to the garage door motor if needed.
Why pay money on hardware to control only your garage door. Go for Z-Wave expand-ability and control every item in your home if and when you decide to. http://www.007systems.com/garage-door-control.html
If you do decide to do this with WIFI please be safe about it and included a camera to see the state of your door and make sure it is clear before you close it from afar. you don't want to injure or kill someone closing it with your phone.
A rasPi is a bit overkill, but a ethernet relay will probably cost more.  But it has a 100Mb port.  Also keep inmind the RasPI GIOPs are 3.3V.
Looking for wired or wireless solution?
What are you looking to do exactly?
Be able to open/close remotely? (ponder security concerns)
Monitor if its open/closed?  (will need 2 inputs and switches/sensors for open/closed) Close if night/bed time?  Send a warning?
Yes a small signal relay tied in parallel ('OR') to the open/close switch.
A RazPi would be perfect for this.  Get yourself a poe injector and adapter for the raspi, a simple current sensor on one of the power leads on the garage door opener (a simple ring of copper wire around the positive or negative lead on the door opener.)  You could do things like turn on a camera while the door is in motion, send you an email/text, etc.
Yes, it's definitely possible and shouldn't be too difficult. This is my next Pi project if I ever get around to it. If you don't do something crazy complicated, the delay shouldn't be any more than the wireless door remote that came with the unit. A friend of mine is part of the startup Garageio (https://garageio.com) and if you look at some of their older videos you'll see that they prototyped with a Pi. Yes, the Pi is overkill but it's worth it for the experience and the price.
Eddie Foy? mentioned that the GPIO on the board are 3.3v, but this shouldn't be an issue either. I'd recommend just getting a separate relay board and I've had no problems controlling that off the 3.3v.
I've already setup something similar a couple Christmases ago where I connected the Pi to a relay board and used that to toggle power to an outlet where Christmas lights were plugged in and created a strobe. I chose to make it more complicated than it needed to be, but it gave me experience with a few new things: php updated a MYSQL DB then Python read the DB and updated the PWM accordingly... Maybe I'll do a post on if I can find that code somewhere.
Garage door openers often get lost, or members of my large family sometimes get dropped off at home without a key, so it would be a general access solution. As well, it would give me the ability to set up temporary logins for others, giving friends or babysitters temporary access to the house without giving them anything (they just use their phone), which can also be revoked easier than a key
RasPi cheapest (but still overkill) $35 for it, $5-10 for SD card and about $10 for misc parts.  Now for the interface.... Run a web server with a Python plug in on the Pi?  ssh into the Pi and run a script?
Wouldn't just a combo keypad mounted outside  be easier?
The Pi gives SO MUCH POTENTIAL! I saw one project that gave a spoken audible alert when the door was opening/closing. One that was controlled by "Ok Google" on his phone. One that had an Asterisk PBX built in and you could call it to open the door. Most projects have Webcam attached so you can see who's coming/going.
The real question is, why would any geek who owns a house NOT do this?
I appreciate your enthusiasm in reinventing the wheel. But please follow some safety rules (UL325 standards) when giving control of a electrically controlled door to an electronic control device.
I would hate to see you hurt someone with your garage door.
The new Ul standards are designed for controlling a door or gate when you are not within visual range of that door or gate.
We have garage door controllers that give a visual and audible notification inside the garage for 5 seconds before the door is closed. We also recommend a camera for viewing a live image of the area before triggering the door We also recommend a door tilt sensor to see the state of the door.
It seems like a lot for a door, but when you away from home and do not know the status of your garage door, or whether you just crushed your neighbors bike, these products are worth every penny.
Ben have you checked out the Electric Imp?  I found this how to video on Geekbeat: http://geekbeat.tv/control-garage-door-internet  Total parts only came to maybe $40, can control 2 doors and only required minor soldering required and it worked the first time - wifi enabled also!
The one problem I have is one Sears door opener I have comes with its own battery backup.  Should power go out, the relay flips to 'closed' I think and triggers the garage door. The opener without batter backup works fine in a power out situation.
I think the sample code supplied above (I just copied, pasted, and changed the login password) might be missing some default settings for the 2 Channel Relay Board, but I'm not an engineer so will be posting for help on the electric Imp boards.
