G+_Ben Yanke Posted December 20, 2015 Share Posted December 20, 2015 I had an idea for a project...I was going to put a RPi inside a permanently installed sound system which can then both record audio at certain times each week (with some sort of auto-transfer mechanism, of course), as well as potentially stream audio out. Is that doable or is the Raspberry Pi under powered for a project like that and don't even think about it? Link to comment Share on other sites More sharing options...
G+_610GARAGE Posted December 20, 2015 Share Posted December 20, 2015 I don't think the pi would be underpowered for that. I run rdp on rpi without much stress. And people use it to stream video. Recording audio is nothing comparatively. Not sure how you were thinking of transferring the audio, but a NFS share would probably work quite well for that. Then you're not stressing the sd card with a lot of read/writes. Link to comment Share on other sites More sharing options...
G+_Ben Yanke Posted December 20, 2015 Author Share Posted December 20, 2015 It would be offsite, so I might even just do an SSH transfer with cron. Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted December 20, 2015 Share Posted December 20, 2015 Sounds like a pretty light load for the Pi and could probably even get by with a Pi Zero for the smaller size. Link to comment Share on other sites More sharing options...
G+_Ben Yanke Posted December 21, 2015 Author Share Posted December 21, 2015 Also, another potential problem: how does a sound card work in Linux? If I am doing an audio stream out, can I still record, or is Linux like windows in that with some types of devices (like cameras) and only one program can use a device? Link to comment Share on other sites More sharing options...
G+_610GARAGE Posted December 21, 2015 Share Posted December 21, 2015 Steve Wolf Yea, sorry. I should have specified pi2. But I'm pretty sure they used pi1 for home media thing. I can't think of what its called. Ben Yanke Another thing to think about is whether the pi audio will be good enough. I don't have much experience with it, but I'm pretty sure it doesn't sound great. Maby look into an external audio if you need good audio. Link to comment Share on other sites More sharing options...
G+_Travis Hershberger Posted December 21, 2015 Share Posted December 21, 2015 A Pi with one of those USB sound adapters should do just fine. Use the built in audio adapter to connect a mic and the USB for output. Let's be honest here, unless you plan to spend $300 on a mic, the audio quality on the input side will be just fine. Link to comment Share on other sites More sharing options...
