G+_Ben Yanke Posted January 13, 2016 Share Posted January 13, 2016 Ok, I messed up something, and I am wondering if someone might be able to help.......When I left for work yesterday, my network was working fine. While at work, I (for the first time) used the standard SSH proxy function from my laptop to get back into my home network. When I returned home, I couldn't get a connection to the outside to most domains, though facebook, google, and oddly enough SSH proxying work just fine....Any ideas? Link to comment Share on other sites More sharing options...
G+_Ben Yanke Posted January 13, 2016 Author Share Posted January 13, 2016 Oh, and dropbox works great too. But not much else.... Link to comment Share on other sites More sharing options...
G+_Travis Hershberger Posted January 13, 2016 Share Posted January 13, 2016 Do you have a leftover route to the work network hanging around? Sometimes the routing between networks will get left in place after exiting a session. Removing the route should kick things back into gear. Link to comment Share on other sites More sharing options...
G+_Steve Martin Posted January 13, 2016 Share Posted January 13, 2016 Can you tell us specifically what "standard SSH proxy function." You are referring to? Did you leave an SSH port forwarding process running? Is this Windows, Mac or Linux? Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted January 13, 2016 Share Posted January 13, 2016 Only that device, or all devices? Have you tried rebooting the router? Could it be a DNS issue (can you ping Google.com? 8.8.8.8?) Link to comment Share on other sites More sharing options...
G+_Ben Yanke Posted January 13, 2016 Author Share Posted January 13, 2016 Now mostly working, but port forwaring is a bit weird...I reset the router and now it's working, but when I try to forward port 80 to the webserver on my lan, it's seeming to try and route ALL my incoming port 80 traffic (ie, the pages I'm trying to view) that direction. Ben Reese All devices, not DNS, see above for update Link to comment Share on other sites More sharing options...
G+_Ben Yanke Posted January 13, 2016 Author Share Posted January 13, 2016 And of course, thank you for the help everyone! Link to comment Share on other sites More sharing options...
G+_Ben Yanke Posted January 14, 2016 Author Share Posted January 14, 2016 aaaand I'm back up! Link to comment Share on other sites More sharing options...
