G+_Ben Yanke Posted July 21, 2016 Share Posted July 21, 2016 So, I know next to nothing about graphics cards...am I going to have faster performance with internal graphics or an old Gforce 9400 GT I picked up? I also picked up a few $5 old AMD cards from the local university surplus, and in wondering the same thing there. Or, the question more generalized: is any graphics card better than no grapuuxs card? Link to comment Share on other sites More sharing options...
G+_Travis Hershberger Posted July 21, 2016 Share Posted July 21, 2016 Some graphics card is generally better than integrated graphics. If you want to check, a good place to look is: http://www.tomshardware.com/reviews/gpu-hierarchy,4388.html Link to comment Share on other sites More sharing options...
G+_Reed Hanson Posted July 21, 2016 Share Posted July 21, 2016 What kind of programs are you trying to run? Usually discrete graphics cards will perform better then integrated graphics, without knowing what CPGPU you have, it will be hard to say. Is your computer newer then 5 years old? If it is older, then the 9400GT will be way faster than any integrated GPU, might even be better then a core I7-2500K and its integrated GPU. Link to comment Share on other sites More sharing options...
G+_Ben Yanke Posted July 23, 2016 Author Share Posted July 23, 2016 Awesome guys, thanks! I'll probably stick it in, along with one of the old AMD cards I found at the university surplus store for cheap, and see how it goes! Link to comment Share on other sites More sharing options...
G+_Ben Yanke Posted July 23, 2016 Author Share Posted July 23, 2016 Also, I'll double check when I get my desktop set back up (moving right now) but I think I have an i5 or i7 that's around 3-5 years old. Link to comment Share on other sites More sharing options...
G+_Ben Yanke Posted July 23, 2016 Author Share Posted July 23, 2016 aaaand crap, there's no more PCI slots! Darn! Link to comment Share on other sites More sharing options...
