G+_Donald Kloss Posted July 25, 2018 Share Posted July 25, 2018 I’m setting up a light box and I have a strand of 3528, my question is the bottom conductive, i do see some some traces on the bottom but I’m thinking the glue should be good, i want to stick them to some foil tape. Link to comment Share on other sites More sharing options...
G+_Jeff Gros Posted July 26, 2018 Share Posted July 26, 2018 I cannot comment on your LED strip since I don't have it, but if you're worried, put kapton taped in between to act as an insulator. Or any number of other materials. Link to comment Share on other sites More sharing options...
G+_Donald Kloss Posted July 26, 2018 Author Share Posted July 26, 2018 Jeff Gros thanks for the help I’ll check on that Link to comment Share on other sites More sharing options...
