Power supply question how do I find which power supply will fit, I m able to find dc power suppli...
G+_Donald Kloss
The size is one thing, but then you have to make sure it produces the right polarity. The little symbol - ---(--- + means that the tip is positive. That means when you test with your multimeter it should read 9 (up to 12)V while the red lead is stuck in the hole of the tip and the black lead is touching the outside barrel. And it will read -9 (up to -12)V when the red and black are reversed.
Looks to be a "standard" barrel jack...the simple kind without fancy color tip. Most 12v and 9v Walwart power supplies used this size. Most likely one from a router one will work..and since your pic does't show amps or watts required, it's probably 1amp or less.
I just got a multi plug power supply as shown in this pic - on the bottom left corner... look at the very last plug on the bottom... that's the kind you will need.
https://plus.google.com/110690680341063574122/posts/bguJ3evpVYt
If you have a set of measuring calipers you can just measure the pin and shell diameters and the depth. Then find the closest match from this list of the common sizes. Beware of sizes that seem to fit but are a little loose, they will often give intermittent problems over time.
en.wikipedia.org - Coaxial power connector - Wikipedia
I wouldn't be surprised that a lower voltage may even work provided it can juice the amps enough for the load.
I got this Acer monitor needing a 19.5v input, but next day's resale shop, I could only find a 18v supply having 0.8a spec...but did already have the correct barrel jack size needed to match the monitor. #bingo it works!
See for yourself:
https://plus.google.com/110690680341063574122/posts/gAdwijp3yHj
