Fairly general question: Is anyone having their stream layouts reset on their G+ feeds each time ...
G+_Joseph Cappellino
Chrome and IE do it to me.  I sent a feedback about it this morning.  At least it still work to switch to the multi column layout and back to single column to get into a readable format.
Multi column makes sense in a newspaper or magazine where you have limited height, it makes no sense in an infinite scroll medium.
Not even something broke, something was broken.  The browser still remembers that it should be single column and indicates that it is single column mode despite clearly having multiple columns.  Even better, single column mode works properly if you toggle multi-column mode then switch back to single column mode.  Whatever it is they changed overnight they need to change back until they can figure out why it breaks stuff.
