Need someone who 's good at calculating power consumption rates
G+_Jason Eckelstafer
Need someone who's good at calculating power consumption rates. How long would a Pi3 running RetroPie last if I were to use this battery pack (16750mAh)? Would it simply be 16.750/2.4=6.98H?
http://www.amazon.com/External-RAVPower-16750mAh-Portable-Technology/dp/B00MQSMEEE
Pi2 with a Alpha 1000mw Wifi adapter running reaver full time I was getting about 36 hours on a 7Ah SLA.  That 16Kmah?  I question.  Those cigarette-pack sized batteries have very sketchy and boastful ratings.  (they should come with a packet of salt in the box)
I found out the hard way that the PI3 is sensitive to low voltage when powered via usb. First find a usb power analyzer and test you power supplies. You will be really lucky if you find a psu that puts out 5 volts when powering your pi.
Then there's the problem of trying to find usb cables that can handle the amperage.
If your psu doesn't supply something close to 5v you will see a rainbow colored square in the upper right corner of your display. Some where around 4.8v the pi shuts off wifi, blue tooth, and Ethernet. When the voltage dips past that during boot up it shuts that off and there is no way that I know to bring it back.
The official rpi psu operates at 5.1v.
