Saw a few posts on Synology and stuff, made me think of a question: I was given a new Drobo 5C (y...
G+_Shooter_FPV (Shooter_FP
Saw a few posts on Synology and stuff, made me think of a question: I was given a new Drobo 5C (yep, I've had good luck with them...). I am a sports photographer, and I shoot primarily in RAW, so I have maybe 5 years worth of photos that takes up about 7TB of space on the Drobo. Being right now that's my only location for these pictures, how in the heck can I back up a 7TB (and counting) Drobo? I can't afford to get a Synology-type device, so not sure what my options are... All I ask is PLEASE don't discuss the bad/good/bad on the Drobo... been there, done that, got the t-shirt... :)
I'd say another Drobo, but you're in the same price range as a Synology.
An 8-10TB hard drive would cost $250~$400, but I'm not sure how much I'd want to rely on a single drive for backup. Maybe 2 swapped out in rotation?
CrashPlan or Carbonite are decent options if you have good upload speed. It would probably take a year to complete the initial backup - though I've heard Carbonite will still ship you a disk to seed the backup.
A few months back, KH had an episode on backups, local and online. One was fairly cheap, Glacial(?). If this is just an archive might be an option for long term storage.
Personally, I'm still waiting for the 3d crystal cube being developed that a buddy and I discussed about 35 years ago. :)
If your drobo works for now and all you are looking for is a backup for "just in case" why not just buy a drive and a SATA adapter and copy them over? I think the crossover point right now is about 4TB (ie. 2 4's are cheaper than an 8). You can copy them all to the new storage and then disconnect the new drives and store them. A nice ziplock ESD bag with a little desiccant should be fine. You won't be accessing them after they are full of your files so not having more redundancy in your backup shouldn't be an issue. Then once you are forced to replace your drobo you will still have them untouched and can decide then how much you want to spend.
I have used Amazon drive with prime you get unlimited file and photo storage for $60 a year. It works with Synology directly and can use encryption I control if I want. So that is $5 a month but with slow upload speed very slow. I would also consider DeWayne Shorts suggestion backup or move to external drives your older non accessed photos. I would organize by year label drive and store in fire safe or offsite for emergency backup. You may want to consider an external raid enclosure on a PC or mac to backup to. eshop.macsales.com - External Hard Drive Enclosures For 3.5-Inch Drives From OWC
However for cost your better off looking at WD or similar 8 TB drives USB they are cheaper then drive and enclosure
I am into time lapse photography and have a two freeNAS computers with a bit over 40TB of raw photos. I use rsync to keep one the same as the other. This also has the benefit of keeping deleted files on the box being used to (back up to). This was the best option for me as I was able to repurpose older computers from family members who did not want them any more. I needed to buy the hard disks, sata controllers, and two tower cases. Cost in 2014 ~$500. At that time they both only had ten 2TB drives each. I have been adding larger HD as old drives went down. SpinRite is used to fix some 2TB drives but i can not use SpinRite on the larger drives for some reason. At some point i will move one to my mother in laws house and rsync over a VPN. But I need to get the VPN up and running.
Ben Reese I did Crashplan at one point, got a good Black Friday deal about 3 years ago. Problem was as your storage to them grew, you had to allocate more and more memory to their software running on your PC. I was backing up over 2TB, and the software was dragging so much I had to finally cancel because it was taking over 15 minutes for my computer to boot.
DeWayne Shorts This is what I was leaning towards... even though I've been a computer tech for over 17 years, I never really knew how long a stationary hard drive would last. I'd just dump them on a drive, then store them, like you said. I could even do a Safety Deposit box, or at a relatives house, which would satisfy my off-site backup requirement. How long do you figure the shelf life would be of a hard drive with data on it?
When you are talking about it being written to a drive and then that drive being stored and not used? I think you have a bigger chance of the filesystem the drive is formated in being no longer supported before the drive would die. ESD bag will help protect from outside issues and the drive it's self is a sealed environment. If you pull them out of storage once every 3-5 years and do a system scan of the data they will outlast you. The scan will refresh the magnetic charge on the disk, so refresh the data.
Have you implemented Dual Disk Redundancy in your Drobo? At least you would be protected against TWO disks failing in the One Drobo device. It is not a perfect backup plan since all the data is kept locally but you would not loose any data if even two drives failed within your Drobo. Just a thought.
