A filtering scheduling product that works with Unifi system
G+_Hagos Rush
A filtering/scheduling product that works with Unifi system.
So like most adults, I have children. I would like to do a couple of things:
1. Filter internet content - this I think I can accomplish through using my pi-hole (raspberry pi ad-blocking) to filter out queries (but I would rather not)
2. schedule the amount of time that the iPad can access the internet. So during the week I want 60 mins per day and set schedule limits on the weekend as well.
Is there an add on or a system that I can use in tandem with the unifi hardware that will allow me to do this? There are other systems like the Eero wifi system that does this but without al lof the control that unifi has.
Any assistance or suggestions that anyone can offer would be helpful.
Thanks in advance!
Happy Holidays!
Hagos
Jason Brown Okay, so looking at k9 again it is on a per device basis. I would rather something that is system-wide that I can implement once and then control from a single point.
I would have to install on all iPads, iPhones and computers in the home.
Also, this would be used to cover my guest network. The OpenDNS IP is cool and I will check that.
I use OpenDNS combined with Pi-hole.
Ubiquiti can already block access to devices, but I'm not sure if it will do it on a schedule. If not, put those devices on their own SSID and schedule the downtime for that.
Fing Box is another option. I don't care for its methods, but it has an option to disable devices on a schedule. It just plugs into your network and uses magic (ARP spoofing) to knock devices offline when needed.
K9 sounds good, but I've never trusted parental control software. I was a teen at one time and found it extremely easy to get around the blocks if I needed. Of course, that was many moons ago and I'm sure things have come a long way.
