G+_Michael Kickingbear Posted February 26, 2013 Share Posted February 26, 2013 Hello all. I thought I would post a question.... I am using wire cast on a HP touch smart. Wire cast is not only a software based video switcher, but it is a encoder and video streamer as well. But my touch smart is too underpowered to switch video AND encode on the same machine. So what I would like to do is send the video OUT to a separate hardware encoder to stream the video and audio. (Looking at the livestream PRO) audio can be sent via line out. I cannot figure out how to send the video I see on the display out to another device. There are no ports on the hp. Any suggestions how I may do this? Thanks! Link to comment Share on other sites More sharing options...
G+_Chris Sehorn Posted February 27, 2013 Share Posted February 27, 2013 Wirecast has a feature called multicast. If you can load a SDP file on your encoder you can stream the wirecast video over your LAN. Your HP should at least have an Ethernet port. Link to comment Share on other sites More sharing options...
