I need help figuring out why my network is lagging
G+_Korey Brown
I need help figuring out why my network is lagging. I have a NETGEAR CM1000 modem and a nighthawk x10 router. I’m getting 115mbs down on my 5ghz and 50-70 on 2.4ghz. I have 2 Echos, multiple mobile device, 3 computers, 3 smart light switches, a Harmony Hub, 2 Amazon Fire TVs and 3 wireless security cameras. The cameras go in and out of “no signal” and short of just keeping them wired, I have tried everything to keep them running smooth. My Amazon Fire tv buffers all the time. A friend of mine has the same bandwidth and more devices and it runs smooth. Why can I not get all my devices running smooth? Thanks!!
I bought the Nighthawk X10 thinking my old router couldn’t handle all the devices pulling on the network. I’m still getting the same problem I had with my small asus router. Needless to say my wife isn’t happy I spent $450 on a router that isn’t solving our problem. Haha
what is the signal strengthen where the failing devices are located? I have a Linksys WRT1900AC with DD-WRT and I still have to have 2 access points in our 6 room apt. The issue is the walls. Old Dab and Lath with horse hair in the plaster (Victoria era). Hair reflects the signal. If you have an Android phone install WiFi Analyzer. Also check the broadcast channels and make sure there is no interference. Had a friend that thought his downstairs Roku was junk as his signal strength was strong, but the neighbor on the same channel was stronger and killing his connection.
The only thing wired to the router is a fire tv. Everything else is wireless. One camera is 10 feet away and one camera is in the kitchen on the same floor about 100 feet away. The last camera is in the garage so that weak signal I understand. I get strong WiFi on all floors. The speeds posted are over WiFi and I get those strong signals throughout the house
