G+_William Foster Posted March 19, 2015 Share Posted March 19, 2015 I am building Project Alien-X.... I have all the parts ordered... I have 10 inch and the 8 inch props ordered... What battery do you recommend for the build.... I want as much flight time as I can get and am wanting a slow stable flight. Link to comment Share on other sites More sharing options...
G+_Fr. Robert Ballecer, SJ Posted March 19, 2015 Share Posted March 19, 2015 If you plan on using the 8" props, get a 4S 2200mAh pack. If you plan on using the 10" props, get a 3s 2200mAh pack. Link to comment Share on other sites More sharing options...
G+_William Foster Posted March 19, 2015 Author Share Posted March 19, 2015 Is there any special ratings I will need? charge discharge rated batteries? Link to comment Share on other sites More sharing options...
G+_Fr. Robert Ballecer, SJ Posted March 20, 2015 Share Posted March 20, 2015 25c will do you for now. Also, of you don't mind soldering an adapter, HobbyKing had hard case 4S 5000mAh 25c packs for $25. That's 125 Amp current to play with. Mwuahahahahaha! Link to comment Share on other sites More sharing options...
G+_William Foster Posted March 20, 2015 Author Share Posted March 20, 2015 Thank you for the info.... I ordered a couple 3s off of amazon yesterday... Will checkout the 4S 5000mAh for sure... good price!!! Link to comment Share on other sites More sharing options...
