I saw the latest episode on premise wiring and I have a question about using using all 4 pairs
G+_Ronald Kurr
I saw the latest episode on premise wiring and I have a question about using using all 4 pairs.  A buddy of mine recommended that I run one cable but only use two pairs per head.  He claims that only 2 of the 4 pairs are used so I can get 2 drops out of one cable.  Is my buddy right or is he steering me down a dark path?
It is really easy to pull multiple runs at the same time and Ethernet is relatively cheap.  I'd error on the side of caution and pull an extra wire that you wouldn't use before you try to save a few pennies and pull just one and split it up.  There are some adapters that allow you to use Ethernet cable to transmit things like HDMI, so it is good to have all the wires done properly incase you want to use stuff like that in the future.
Tim Brady - You are correct.  A premise is usually a property of some sort like a building or office.  It can be a home also.
