G+_Justin S Posted October 26, 2013 Share Posted October 26, 2013 Having problems with my RaspberryPi it isn't loading the Gamegear roms. Some go in to launch but don't & come back to the menu while others just act like they are launching but it is a black screen "lockup." Please help me someone. I am getting no where. http://youtu.be/jWrN7Mmi7H0 Link to comment Share on other sites More sharing options...
G+_Justin S Posted October 26, 2013 Author Share Posted October 26, 2013 Hope this is addressed on the next KnowHow episode. Come on KnowItAlls Link to comment Share on other sites More sharing options...
G+_Bryan Burnett Posted October 30, 2013 Share Posted October 30, 2013 Hey Justin, I'm going to test this with my setup and see if i can figure it out. Link to comment Share on other sites More sharing options...
G+_Justin S Posted October 31, 2013 Author Share Posted October 31, 2013 Try the HDMI & composite video outputs. I got it working on the composite output, I had been trying the HDMI output to no luck. Not sure if have a faulty raspberrypi. Link to comment Share on other sites More sharing options...
G+_Bryan Burnett Posted November 1, 2013 Share Posted November 1, 2013 I got mine to work just fine, through the HDMI. I would make sure you have the updated version of GameGear emulator. The only problem I've had so far is not being able to exit out of the emulator with the same mapping i used for the Sega Genesis Link to comment Share on other sites More sharing options...
G+_Justin S Posted November 2, 2013 Author Share Posted November 2, 2013 How would I update the GameGear emulator? Would I go through the same steps knowhow did? Link to comment Share on other sites More sharing options...
G+_Jeff B Posted November 2, 2013 Share Posted November 2, 2013 where do you get the game roms from? Link to comment Share on other sites More sharing options...
G+_Bryan Burnett Posted November 2, 2013 Share Posted November 2, 2013 Justin, do any other games/emulators work through the HDMI? Also to update just the game gear run in terminal; "cd RetroPie-Setup" "sudo ./retropie_setup.sh" Update the Script Update the Binaries Then go into Source-based INSTALLATION *be sure to hit spacebar to deselect the stuff you don't want to update, cause it'll take FOREVER otherwise" Select #31 Install Mastersystem/Game Gear Update it, and let me know if it works :P Link to comment Share on other sites More sharing options...
