So, I 'm on Verizon and have an upgrade available Question is M9? S6? NEXUS6? Droid Turbo?
G+_Michael A
Michael A? Had the HTC One M8, the Moto Droid Turbo and Nexus 6. Currently using the Nexus 6 as my daily driver. All 3 phones have their strengths and weaknesses.
The HTC One M8 has the best build quality, great battery life, great front facing speakers uber fast and light skin but camera was not up to par, no Qi charging capability.
The Droid Turbo has a rugged build, best battery life even with the beautiful but power hungry QHD display, best and fast camera out of the 3. The downsides being the capacitive buttons, lackluster design and slow upgrade to lollipop.
The Nexus 6 has the most complete feature set, nice design, good camera, best QHD display out of the 3, dual front facing speakers, Qi charging capability, lollipop and latest updates right out the gate. But Battery life leaves you wishing you can get more than a day given the battery size.
It all comes down to personal taste and what you value most. If the M9's new 20 megapixel camera is a significant improvement and adds Qi charging capability then that would be my personal choice since it ships with Lollipop.
Hope this helps.
Just got a nexus 6 and loving it. So far the best phone I have ever had. All the other phones have so much bloat. The nexus comes loaded with some but it is all installed from the play store so you can completely uninstall it.( not just disable like some others) Plus they are easy to root if you want to freshen up the experience before your next upgrade. To top it all off you get the fastest android upgrades. Nexus is already running 5.1.
