G+_Tom T Walker Posted February 22, 2017 Share Posted February 22, 2017 Have been using Logitech's low end wireless keyboard and mouse for years. They are good for the price, but would like to upgrade to a nicer keyboard with high-end tactical feel. Any suggestions? (For a Windows machine) #keyboards Link to comment Share on other sites More sharing options...
G+_Joe Morrison Posted February 22, 2017 Share Posted February 22, 2017 You probably should pick a price range and decide what your must have and nice to have features are. Then you should go to a store where you can put your hands on a few different keyboards and buy the one that fits you best. Something that forms that personal connection between you and your computer should definitely be a try before you buy situation. I prefer a bit of slant, not too "clicky" or noisy, and consider backlighting to be pretty important. You probably have different preferences. Link to comment Share on other sites More sharing options...
G+_Tom T Walker Posted February 22, 2017 Author Share Posted February 22, 2017 Thanks +Joe Morrison. I'll definitely do that. As I recall from a few years back the selection at Best Buy or Office Depot was kind of slim, but maybe will get lucky this time. Hoping for a wireless keyboard/mouse combo with a nice clicky feel, but quiet. Backlight is optional. No ergonomic split. If I get replies here with suggestions, I'll look for them locally first, then online. Link to comment Share on other sites More sharing options...
G+_52Degrees Posted February 22, 2017 Share Posted February 22, 2017 Go to Wal-Mart and try a Razer keyboard. They're on display at most of the big ones. You'll know if you like mechanical or not pretty quickly. Link to comment Share on other sites More sharing options...
G+_Kunal Vaidya Posted February 24, 2017 Share Posted February 24, 2017 Tom T Walker? check if Logitech 610 is something you might like. Backlit, cherry brown keys (silent then normal blue) and understated design. Link to comment Share on other sites More sharing options...
