Quick Review: Chameleon Launcher (Beta) for phones
G+_Marlon Thompson
So the beta of Chameleon Launcher for phones is out and I have been using it off and on for the last few days. Note it only works on phones with resolution of 720 x 1280 and up so only flagship phones need apply.
Pros
Its pretty!!
Transitions are nice and customization is as easy as they were on the tablet.
You can use native widgets as well as the chameleon widgets
Cons
I found it laggy at times (it is a beta so that may improve)
You are limited to 3 screens
Native widgets sometimes break the whole design aesthetic of the launcher
Seems to be a bit of the battery hog.
Final thoughts: Its a beta so certain things will improve but for right now I'm sticking with Nova launcher. I'll give an update when it is finally released.
