G+_Ari Nugroho Posted August 31, 2013 Share Posted August 31, 2013 can anyone help me i recently go the LG Optimus G Pro and the Android OS is using large amounts of data 1gb in 3 days the next closest thing is Amazon Cloud Drive with only 23mb does anyone know what is using the data so I can stop it? it's a company phone and i only have 5gb of data a month. Also I turned off mobile data and it has used 1gb in wifi data in about 2 days Link to comment Share on other sites More sharing options...
G+_Jakub Baczynski Posted August 31, 2013 Share Posted August 31, 2013 what apps are you using? marine something which suppose to use only wifi? Link to comment Share on other sites More sharing options...
G+_shamara Lewis Posted August 31, 2013 Share Posted August 31, 2013 only a few but they list their data and they are all under 30mb Link to comment Share on other sites More sharing options...
G+_Jakub Baczynski Posted August 31, 2013 Share Posted August 31, 2013 interesting... no video streaming, p2p other cloud sync? Link to comment Share on other sites More sharing options...
G+_shamara Lewis Posted August 31, 2013 Share Posted August 31, 2013 no i used youtube but it only used 4.38mb i dont have auto sync on because its a work phone and i don't want to sync something by accident that i didn't want on my work phone Link to comment Share on other sites More sharing options...
G+_Jakub Baczynski Posted August 31, 2013 Share Posted August 31, 2013 well... i'm running out of options then. have a look at battery usage and see what app useing most power. if it uses power it may also use a lot of data, maybe it's something your employer installed? Link to comment Share on other sites More sharing options...
G+_shamara Lewis Posted August 31, 2013 Share Posted August 31, 2013 screen 60% next OS 8% Link to comment Share on other sites More sharing options...
G+_Jakub Baczynski Posted August 31, 2013 Share Posted August 31, 2013 so it's not that because screen does not use data... no idea than... Link to comment Share on other sites More sharing options...
G+_shamara Lewis Posted August 31, 2013 Share Posted August 31, 2013 i was using go launcher and locker i think this may be the cause i'm going to monitor the usage for a day and see if that was it when i looked at all my apps info it showed had access to the network Link to comment Share on other sites More sharing options...
G+_shamara Lewis Posted August 31, 2013 Share Posted August 31, 2013 Paul Roberts i did that and it said Android OS Link to comment Share on other sites More sharing options...
G+_shamara Lewis Posted August 31, 2013 Share Posted August 31, 2013 using 1gb Link to comment Share on other sites More sharing options...
G+_Skylar Wicklander Posted August 31, 2013 Share Posted August 31, 2013 Since you just got the phone, could the large amount of data simply be the initial syncing of all of your apps and etc? Link to comment Share on other sites More sharing options...
G+_Jakub Baczynski Posted August 31, 2013 Share Posted August 31, 2013 not that much of data i'm afraid Link to comment Share on other sites More sharing options...
G+_Jamie King Posted August 31, 2013 Share Posted August 31, 2013 When I got my Nexus 7 last month it showed a large amount of data on the first app sync, IIRC it may have been close to a gb. Link to comment Share on other sites More sharing options...
G+_shamara Lewis Posted August 31, 2013 Share Posted August 31, 2013 But it has used 1gb of mobile data and 1gb of WiFi just on android is that's still a lot of data ? Link to comment Share on other sites More sharing options...
G+_Michael Abernathy Posted August 31, 2013 Share Posted August 31, 2013 Go to your accounts. Check and see if the Google account has one of the many things it updates stuck. If it is stuck it will be the only item in the list with a little circle with arrows on it. Uncheck the box beside it if you don't need it or Uncheck it and then recheck it to hopefully force the stuck update. Link to comment Share on other sites More sharing options...
G+_Bjørn-Eivind Kvam Netla Posted September 1, 2013 Share Posted September 1, 2013 I noticed that Dropbox was trying to download everything to my phone, do you use Dropbox? Link to comment Share on other sites More sharing options...
G+_Nana Yaw Ofori Posted September 1, 2013 Share Posted September 1, 2013 I've heard that there's an issue with some versions of CyanogenMod resulting in Google Services repeatedly attempting to download 4.3 OTA on wifi or mobile networks, resulting in usage spikes similar to this one. I'm not familiar with rooting and installing roms, so I'm uncertain about the actual specifics. http://www.cyanogenmod.org/blog/cyanogenmod-10-1-3-rc1/comment-page-1#comment-1021438017 Link to comment Share on other sites More sharing options...
