G+_Ari Nugroho Posted September 21, 2015 Share Posted September 21, 2015 I need so help guys. My son just got a surface tablet. Does anyone know how to sync his Google stuff? Gmai, contacts, etc. Every time I tried to add the account it errors out. I know the password is correct we just reset it. Link to comment Share on other sites More sharing options...
G+_shamara Lewis Posted September 21, 2015 Share Posted September 21, 2015 Michael Burke? no it doesn't Link to comment Share on other sites More sharing options...
G+_shamara Lewis Posted September 21, 2015 Share Posted September 21, 2015 Also the tablet is updated to windows 10 if that helps Link to comment Share on other sites More sharing options...
G+_joseph Posted September 21, 2015 Share Posted September 21, 2015 Just go to gmail.com instead of using Windows apps. Link to comment Share on other sites More sharing options...
G+_shamara Lewis Posted September 21, 2015 Share Posted September 21, 2015 I know that I can use Chrome to access I just wanted to use the mail and calendar app like Michael Burke?? mentioned Link to comment Share on other sites More sharing options...
G+_Mark Stronge Posted September 21, 2015 Share Posted September 21, 2015 I've never added them as I use chrome but from what I've read, it should be possible. Link to comment Share on other sites More sharing options...
G+_Julie Wills Posted September 21, 2015 Share Posted September 21, 2015 I'm fairly certain that Google and Windows mobile (or whatever they're calling it these days) don't play nicely together. You will probably need to use a synchronisation tool to sync contacts and calendar. Maybe Ted Salmon? can help on this one? Link to comment Share on other sites More sharing options...
G+_Jared Twomey Posted September 21, 2015 Share Posted September 21, 2015 Google accounts should connect and sync fine with the built in Mail and Calendar app in Windows 10. I have 6 different Gmail/Google Apps accounts connected to mine and they all work perfectly fine. Link to comment Share on other sites More sharing options...
G+_L I Posted September 25, 2015 Share Posted September 25, 2015 It should be able to add the mail via IMAP - if not you can set it up manually. You should be able to google the settings like "gmail IMAP setup" As for calendar and contacts I'm not sure as I haven't tried. Worst case you could export/import. Link to comment Share on other sites More sharing options...
G+_Julie Wills Posted September 25, 2015 Share Posted September 25, 2015 On a surface, why not just use the web interface, the same as you would on a laptop / desktop? Link to comment Share on other sites More sharing options...
G+_Jared Twomey Posted September 25, 2015 Share Posted September 25, 2015 Julie Wills because some people prefer a mail client. I have 7 different email accounts (a mix of company, other business, and personal). Some Gmail, some not. It's nice to have all my email in one place, thus I use a mail client. Link to comment Share on other sites More sharing options...
G+_shamara Lewis Posted September 26, 2015 Share Posted September 26, 2015 Thanks guys I ended up just waiting a couple days then it worked. Link to comment Share on other sites More sharing options...
