Using Tasker
G+_Graham Forte
Using Tasker
I avoided using Tasker for a long time, as I didn't want to drop the $6.49.  I now regret waiting.
I use Google Voice (Gmail) as my primary number.  The lack of MMS and short code support not withstanding, it's really great to change the forwarding phones automatically based on which WiFi Network I'm connected to.  So, when I arrive at a location it turns on the relevant phones, and when I leave said location it turns off the relevant phones.
I also use it to enable/disable my lock code, as mentioned by Gary A Hanson, when I connect/disconnect from the bluetooth devices in my car.
And, as Jason Howell mentioned in the show, I use it to set my volumes to silent at night, when plugged in.
Aside from that, there isn't anything that I need to happen automatically.  I had even bought a bunch NFC tags to try to "automate" my life.  But, NFC doesn't work with the phone locked (understandably so) which makes it only pseudo-automatic.
I agree, that Tasker is rather daunting to setup, but the Beta has made this a little better.  Also, in recent versions, you can export a Profile as an app which can be installed on any device.
I was using Tasker like you for basic turning on and off things based on location. I had to remove it for now because it was just killing my battery. It's probably my fault because I haven't taken the time to optimize (if it's even possible) the routines I setup. An app like Tasker requires a lot of time on your part to eventually save you time in the future. If you don't have a logical computer programmer's mind and the time it takes to program then it'd be best to save the $6.49. When I manage to finally find some time in my life again I might give the beta a try.
Remember that the phone is always using it's radio to get the service, and even though wifi uses less signal let's suppose that you've lost your wifi for a weekend, it's pretty handy to have another method besides wifi or gps, which llama also uses by the way!
By the way I remember this was once a topic in one All About Android
