G+_Jason Fleisher Posted September 12, 2013 Share Posted September 12, 2013 I need some help from my fellow AAA listeners (and hosts). I am being provided with a phone from my employer. The problem is, I can choose Verizon, AT&T or Sprint and any phone I want. Nice problem to have but what should I get? I've been with Sprint for years and am using a Galaxy Nexus with CM10.1. I'm getting tired of Sprint because they have yet to roll out LTE in my area (Tucson). So, here are my thought: LG G2 Pros: AWESOME hardware! Cons: LG's reputation for supporting their phones. Carrier: Verizon has Qi charging, but usually cripples their phones. Moto X Pros: Lots Cons: Pretty much the same screen I have now. Would love HD but it wouldn't kill me. Not sure I can get the 32GB version. Have to buy through Carrier website. GS4 Pros: Good phone, CM available, GPE available. Cons: Can I put the GPE Rom on it? Maybe just the AT&T version? HTC One Pros: Nice phone. Not much else to say. So, what do you recommend? Company is switching to Verizon but I think I can still get AT&T if I want. That G2 hardware is very tempting. Thanks for any advice you have! Jason Link to comment Share on other sites More sharing options...
G+_Lucas Nichols Posted September 12, 2013 Share Posted September 12, 2013 I would say it depends on how you are going to use the phone. What's more important calls or data. Verizon would probably give you the best reception. But what happens if you go over their data cap? Also is the phone going to be restricted? Like certain websites blocked, certain apps disabled? If you aren't going to be restricted by data caps or limited functionality I would go Verizon. Because of their superior coverage. Out of the phones listed I would probably try the LG. The gs4 has limited memory, the htc and moto X don't have removable batteries and I refuse to support them. Link to comment Share on other sites More sharing options...
G+_Jason Fleisher Posted September 12, 2013 Author Share Posted September 12, 2013 Lucas Nichols I don't have to worry too much about data caps on the corporate plan. I'm pretty sure the US version of the G2 doesn't have a replaceable battery either. But this 3000 mAh battery is supposed to be really good. One of my main concerns is if I will able to root it. I can live with stock but I would be lost without root for backups and tweaks. Link to comment Share on other sites More sharing options...
G+_Joe Morrison Posted September 12, 2013 Share Posted September 12, 2013 I don't have strong feelings either way for the phones listed. I would also recommend Verizon, particularly since you don't have to foot the bill yourself. I have found their general coverage and LTE coverage to be excellent and on LTE the bandwidth available is phenomenal. I am generally seeing 10-30 Mb down and 4-10 Mb upload speeds. Verizon does tend to lag in pushing updates to phones though, so be sure you are happy with the phone you have rather than focusing on what it will become with future updates because you will be waiting months for the updates to roll out. My S3 is still on 4.1.2 and I haven't heard anything about when there may be more updates. Link to comment Share on other sites More sharing options...
G+_Q. Davis Posted September 12, 2013 Share Posted September 12, 2013 Hard luxury problem to have, Jason Fleisher . Lol. I'd prob go with AT&T as my carrier so you'll have a GSM-LTE carrier instead of a CDMA-LTE carrier and you mentioned that Verizon cripples devices and you had problems with Sprint so there you go. As far as hardware, I'd prob go with the Moto X. Since I'm recommending AT&T, at least you can use MotoMaker to get a custom device and later you could root and add a custom ROM to finish the overall custom look. Either way, I'm super jealy so best of luck regardless of what device/carrier you choose. ^_^? Link to comment Share on other sites More sharing options...
G+_Robert Carlos Posted September 12, 2013 Share Posted September 12, 2013 If it's a work phone, why not go Note 2 if you can't wait for the 3. Samsung promises to update to 4.3. I'm not sure what type of business you're in so maybe that won't matter much to you. I like the HTC One the most out of the ones you gave us to choose from. Great hardware. Link to comment Share on other sites More sharing options...
G+_Jason Fleisher Posted September 12, 2013 Author Share Posted September 12, 2013 Thanks for the input. I ended up getting the LG on Verizon because I just couldn't pass up on the shiny newness :-) Verizon because that's what has the best coverage here and I figured that if work is paying for it I should be easy to get a hold of. Link to comment Share on other sites More sharing options...
