G+_Ronald Cole Jr Posted December 8, 2015 Share Posted December 8, 2015 Need help deciding what phone to get. Either the Galaxy Note 5, the Galaxy s6 edge plus or the LG v10?? Link to comment Share on other sites More sharing options...
G+_Paul Graham Posted December 8, 2015 Share Posted December 8, 2015 I would say the LG v10. Check out the high on android honest unboxing and review of the v10. Link to comment Share on other sites More sharing options...
G+_John Rischmiller Posted December 9, 2015 Share Posted December 9, 2015 Depends on your criteria. My Note 5 is awesome but I'm an S-Pen devotee. The functionality is great. Link to comment Share on other sites More sharing options...
G+_Luis Padilla Posted December 9, 2015 Share Posted December 9, 2015 John Rischmiller The Note 5 does look awesome & so does the GS6 Edge+. I like the extra weight of the Note 5 and how it feels in the hand. Now the Note 5 is available in gold, I might get it. Link to comment Share on other sites More sharing options...
G+_John Rischmiller Posted December 9, 2015 Share Posted December 9, 2015 I'm sure you won't be disappointed. Mine is in white as that was the only 64GB available at the time, and I had to have a grey import as it's not officially available in the UK yet. Link to comment Share on other sites More sharing options...
