G+_Jay Greenleaf Posted April 27, 2015 Share Posted April 27, 2015 Did anyone investigate whether GPS works more efficiently in lollipop than kitkat? I recently tried two golf apps and the distance computation seemed to be near instantaneous. I was wondering if Google upgraded something in GPS location , which golf apps rely on. Link to comment Share on other sites More sharing options...
G+_Neil Sedlak Posted April 27, 2015 Share Posted April 27, 2015 It's likely you had something else already using location, so it didn't need to wait the normal period to get a lock. That could possibly be that LP turned on high accuracy by default, or that you used navigation to get to the course, or some other app like photo location, etc. Link to comment Share on other sites More sharing options...
